If you have moved, you find menue points for indicating that you moved. You should / must do this anyhow. If you have “lost” the old Box 2, I assume that you will be charged. Normally you have to send the old one back in case you get a new one… charge unknown, but I guess between 100 and 250??? So perhaps you can still get the old one?
