8109878089 Position of the TV is not close to the antenna socket on the wall. How can we connect then TV box, if the distance should be at least 5m?
Sunrise_Team Hello @8109878089 Thanks for your message. Do you need a cable with a minimum length of 5 meters? Kind regards, Matti
