In connecting my new UPC TV box, the instructions state not to use a Multimedia adapter, but to directly connect everything into the wall, including my Connect Box. Based on the old cables I have from when I received the Connect Box which do not seem to fit into my wall connection, I have always been using the old Multimedia adapter. If I now want to plug the Connect Box directly into my wall connection, what cable do I need? The instructions only show for 2-Loch or 3-Loch. I have what looks more like a UKV-Dose with coaxial connections (there is no ‘broadband connection’ like shown for Cable A) , but the help page for that is very vague. Should I order a Cable A or Cable B or? I never received either of these with my Connect Box.
For the moment, everything works with the Multimedia adapter, so can I just continue using it? If not, what cable do I need from UPC for my Connect Box?
Thanks for any advice.
