fyrtif Hello, I’m trying to do some port forwarding, but I noticed that I can’t use IPv4 addresses for the ports. How can I edit settings using devices’ IPv4 address? Thank you.
Daniele_Sunrise fyrtif Welcome to the community! Please send us your customer number, address and date of birth via private message. We will be happy to check the configuration of your modem. Greetings Daniele
Daniele_Sunrise fyrtif There is currently a pending order in the system (porting per 30.04.2024), which prevents the activation of IPv4. Please contact us again as soon as you have been informed via SMS / email that your products have been fully activated. Greetings Daniele
fyrtif Hello Daniele, The pending order issue has been solved. Could you, please, active the IPv4 routing ? Best regards Fyrtif
fyrtif Hello, The router has only IPv6 routing options. As my internal devices are IPv4 (NAT) and I have to access some of them from internet, I need the IpV4 routing option to be active. I have seen that this is just an easy configuration from sunrise’s side. can you arrange that ? Best regards Fyrtif
fyrtif Hello Daniele, I restarted the router and the “golden” menu entries are here. Super ! Thank-you very much for your support. Have a nice day Best regards Fyrtif
