paalia Got an ancient MBP at home (A1425), which is up to date iOS wise. Since I got the connect pod it doesn’t connect to wifi anymore when in range of the pod. Near the main (?) modem it works fine. Have had no issues with any other devices.. Any ideas?
Sunrise_Team Thank you for your question. Do you have IPv4 activated? This could be the issue. Kind regards, Jessica.
paalia Hi Jessica, both IPv4 and IPv6 are activated and set to DHCP. Running 10.5 Catalina for what it’s worth.
