Quite often when I start my tv in the morning I get a message “no internet connection”.
When I check the Ethernet cable the light is blinking.
If I unplug the Ethernet cable, wait a few seconds, then plug it back in usually the TV starts again.
This is the same Ethernet cable I used for years with my previous supplier without any problems.
A wireless connection works OK but it is recommended to use the cable connection.
How can I improve my cable connection.
