• TVSunrise TV
  • English
  • AV Input via Sunrise remote control
Sunrise
IP TV Box
can I use the Sunrise remote control to switch to other HDMI sources on my TV?
Ähnliche Diskussionen
Yes, you can use the Sunrise remote control to switch to other HDMI sources on your TV. Here are some steps to guide you through the process:
  1. Remote Control Pairing: Ensure that your Sunrise remote control is paired with your TV. Go to “Settings” > “Picture & Sound” > “Remote Control Pairing” and follow the instructions.
  2. Switching Sources: a. Press the button with the microphone symbol located at the top of the remote control. b. Speak the command: “Switch to [Name of the input source].” For example, say “Switch to HDMI 1” if you want to switch to the HDMI 1 input source. c. Your TV will recognize the command and switch to the specified input source.
Kind regards
Jessica
6 Monate später
