merki-joshy I have a DSL Router. And with it, I got 2 Connect Pods 1. I also got from another Location a Connect pod 2. Can I use the Connect Pods 1 with the Connect Pod 2 with the DSL router?
Sunrise_Team merki-joshy Hello merki Thank you for your message I just checked in our system and here is your answer: With the connect box 3 that ends with D2B you can use the two connect pods 1 that are ending with 5A2 & 59F. With the other connect box 3 that you own that ends with 782 you can only use the connect pod 2 that ends with B7D. You cannot mix the two of them otherwise it won’t work. I hope this could help and have a great day. Kind Regards Claudio
