hi,
I tried various suggested solutions to fix the internet drop but no avail.
Here are the details:
1. I use the modem Technicolor TC7200
2. Inbetween my bedroom and sitting room where the modem is connected lies the kitchen and my daughter room. Its is 7 meter distance.
3. Around 5 devices are connected to my wifi.
Problems.
The wifi interent connectetion drops intermittently. It comes back after some seconds and then goes away. In order to resolve this problem sometimes I shut off the modem for 30 seconds to restart the connection.
I changed onetime the frequency band from 2.4 ghz to 5 ghz to test the connection but problem still persist.
Ask.
Is there anyother way other than the optimisation tips that you offer in our website.
Can I get the new modem Connect box because I learned from my friend it works very well in Geneva.
Awaiting your actions
dawa
