Dear Mrs Andonova,
Since our last email exchange, I have been trying many times setting up the PPPoE connection withoutt any success.
Based on the logs it seems that there is an authentication failure.
Fri Mar 15 13:53:39 2024 : publish_entry SCDSet() failed: Success!
Fri Mar 15 13:53:39 2024 : PPPoE connecting to service 'grb.ims.sunrise.ch' [access concentrator '']...
Fri Mar 15 13:53:39 2024 : PPPoE connection established.
Fri Mar 15 13:53:39 2024 : using link 0
Fri Mar 15 13:53:39 2024 : Using interface ppp0
Fri Mar 15 13:53:39 2024 : Connect: ppp0 <--> socket[34:16]
Fri Mar 15 13:53:39 2024 : sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x3bc23706>]
Fri Mar 15 13:53:39 2024 : rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0x3bc23706>]
Fri Mar 15 13:53:42 2024 : rcvd [LCP ConfReq id=0x2 <mru 1500> <auth chap MD5> <magic 0xf989a89e>]
Fri Mar 15 13:53:42 2024 : lcp_reqci: returning CONFACK.
Fri Mar 15 13:53:42 2024 : sent [LCP ConfAck id=0x2 <mru 1500> <auth chap MD5> <magic 0xf989a89e>]
Fri Mar 15 13:53:42 2024 : sent [LCP EchoReq id=0x0 magic=0x3bc23706]
Fri Mar 15 13:53:42 2024 : rcvd [CHAP Challenge id=0x1 <518b590be8f658ad5b21daa0424a606d>, name = "Huawei"]
Fri Mar 15 13:53:42 2024 : sent [CHAP Response id=0x1 <b4197dd9825c53d054ef7f0c5ce24b8f>, name = "v01655883873"]
Fri Mar 15 13:53:42 2024 : rcvd [LCP EchoRep id=0x0 magic=0xf989a89e]
Fri Mar 15 13:53:42 2024 : rcvd [CHAP Failure id=0x1 "Authentication failure"]
Fri Mar 15 13:53:42 2024 : CHAP authentication failed: Authentication failure
Fri Mar 15 13:53:42 2024 : sent [LCP TermReq id=0x2 "Failed to authenticate ourselves to peer"]
Fri Mar 15 13:53:42 2024 : Connection terminated.
Fri Mar 15 13:53:42 2024 : PPPoE disconnecting...
Fri Mar 15 13:53:42 2024 : PPPoE disconnected
Any idea what could go wrong ?
Thanks for your help
Kind regards
Martin
