Technical details:
Technology DOCSIS 3.0, Docsis 3.1
Connections 2x Tel , 4x LAN, 1x Coax, 1x Power
Wifi 2.4 Ghz, 5 Ghz, WPS
Dect No
Max. Access Speed 1000/ 100 Mbit’s
Max. LAN Speed 1 Gbit/sLine Ports 1 x RF F-type (Coax) 2x FXS
Power consumption standby: 16.31 watts (modem standby, WIFI on)
Power consumption active mode: 18.99 watts (traffic with 4 users WIFI and 1 user LAN)
Dimensions L: 91 mm W: 116 mm H: 205 mm
1. WPS Button
2. RJ45 connectors for Ethernet LAN connection
3. RJ11 connectors for phone Line 1 +2 (Only Line 1 usable!)
4. Reset button (recessed)
5. Coaxial antenna connector
6. On/Off switch
7. Power supply connector for power supply
Overview of status lights:
Bright White Illuminated
- Modem registration on CMTS successful
- Startup process complete
White pulsating
- Startup process
- Search for downstream signal
- Search for upstream signal
- IP reference from DHCP
- Loading bootfile from TFTP
Weak White glowing
- Modem registration at CMTS successful
- Startup process complete- In operation
Red glowing
- CM registration failed
- Network access denied (CM unprov.)
Red flashing
- Telephone fault
- WLAN malfunction
- Fan defective or other hardware error
- Restricted operation due to error
Blue glowing (max. 20sec.)
- WPS successfully connected
Blue pulsating (2sec on/ 1sec off - 120sec long)
- WPS is connected
Blue flashing
- WPS session expired
Blue fast blinking
- WPS Error
Green pulsing
- Firmware update in progress
Installation guide:
Greetings
