Technical details:
Technology DOCSIS 3.0, Docsis 3.1
Connections 2x Tel , 4x LAN, 1x Coax, 1x Power
WiFi-6, 2.4GHz, 5GHz, WPS
Dect No
Max. Access Speed 1000/ 100 Mbit’s
Max. LAN Speed 1× 2.5 Gbit/s / 3× 1 Gbits
Line Ports 1 x RF F-type (Coax) 2x FXS
Power consumption 36 Watt
Dimensions L: 190mm W: 45mm H: 240mm
1. RJ45 Ethernet / LAN connection 1 Gbit/s
2. RJ45 Ethernet / LAN connection 2.5 Gbit/s
3. RJ11 analog phone ports line 1 + 2 (only line 1 usable)
4. Coaxial antenna connector
5. Power supply connector for power supply
6. On/Off switch
7. Reset button (bottom side of the router)
LED status lamps
White flashing
- Self test, start boot process
- Scan downstream
- Scan upstream
- Registration (DHCP/ToD/TFTP)
White on
- Registration successful, ready for operation
Red blinking
- No fiber signal found, possibly cable not connected
Yellow flashing
- Connection cannot be established (timeout)
Yellow light
- Provisioning cannot be received (timeout).
Green blinking
- Firmware Update
Blue flashing
- Missing WAN IP address
Installation instructions:
Greetings
