Technical details:
4 x antennas
AX4200 Gigabit WiFi (580/1200/2400Mbps)
802.11ax 2.5GHz
802.11ax 5GHz
DDR 3 - RAM 512MB
Nand Flash - 512MB
Giga ports:
1 × 10/100/1000 Base-T
1 × 10/100/1000/2.5G Base-T
WiFi security: WPA2-PSK (AES), WPA 3
Dimensions: 95.5 mm / 86.7 mm / 40 mm
Weight: 217g
Power supply: 110 - 240VAC 50/60Hz
Power consumption standby: 4.04 Watt
Power consumption active mode: 8.69 Watt
Installation:
Status of lamps:
Slow pulsing: The Connect Pod is trying to connect to the router’s network.
Causes: The Connect Pod has lost connection to the router because the router is rebooting or powered off, or the Connect POD is too far away from the modem and cannot connect.
Rapid pulsing: There appears to be a problem with the Connect Pod.
Causes: The Connect Pod appears to be defective and may need to be replaced.
Greetings
