Hello,
I have Surf protect active and it seems to pose a problem to NordPVN, which give an invalid TLS certificate error for a self-signed certificate by Secucloud (c.f. attached screenshot). Looking at other posts it seems that this is caused by Surf protect, which would make sense. It also seems like disabling Surf protect from MySunrise is a valid solution, but I would like to keep the extra protection as well as be able to use the VPN. Is it safe to trust the self-signed certificate, or is disabling Surf protect the only option? Thank you!
