Daniele_Sunrise mtommy84
Its not…
Link Local
These are meant to be used inside an internal network, and again they are not routed on the Internet.
It is equivalent to the IPv4 address 169.254.0.0/16 which is allocated on an IPv4 network when no DHCP server is found.
Link local addresses start with fe80
They are restricted to a link and are not routed on the Internal network or the Internet.
Link Local addresses are self assigned i.e. they do not require a DHCP server.
A link local address is required on every IP6 interface even if no routing is present.
