Internet connection speed seems to be highly variable when connected to the mesh, even though the signal strength, according to the app, is ‘excellent’. Is there anything i can check / change in the settings to ensure I am getting the best result?
FYI, download speed on the mesh is less than 6 Mbps, quite often with a much higher upload speed (~50Mbps), whereas both upload and download are more like 150-200Mbps when connected directly to the main router.
Thanks!
