I tried to set fixed speed and disable MDI-X but nothing happens.
More details below:
I'm using Proxmox as the OS. The network card is enp130s0. Here is the output of "ip a" when it is connected to my mac. The ethernet sharing (as a bridge) works in this case.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether ac:1f:6b:75:fe:e0 brd ff:ff:ff:ff:ff:ff
altname enp5s0
3: eno2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether ac:1f:6b:75:fe:e1 brd ff:ff:ff:ff:ff:ff
altname enp6s0
4: enp130s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master vmbr0 state UP group default qlen 1000
link/ether a0:36:9f:bc:db:7c brd ff:ff:ff:ff:ff:ff
5: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.2.2/24 brd 192.168.2.255 scope global dynamic vmbr0
valid_lft 85542sec preferred_lft 85542sec
inet6 fe80::a236:9fff:febc:db7c/64 scope link
And the "ethtool enp130s0" gives the following:
Settings for enp130s0:
Supported ports: [ TP ]
Supported link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
When I connected to Connect Box 2 (directly or via a switch), "ethtool enp130s0" gives:
1000baseT/Full
10000baseT/Full
1000baseT/Full
10000baseT/Full
Speed: Unknown!
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
drv probe link
Link detected: no
It appears that the Connect Box 2 doesn't want to talk with it. I have another management port on this server, it can be connected to Connect Box 2 with the same cable and socket. So the problem remains between my network card and Connect Box 2.
I tried the advised solution using "ethtool –s enp130s0 speed 100 duplex full autoneg off" command. It takes no effect on the result.
