jcbang I can not get whatsapp call to work on my home wifi connection. Only on cellular connection. Does anyone know why it is blocked? It says that my wifi network prevents whatsapp calls.
Daniele_Sunrise jcbang Welcome to the community! It may be that your firewall blocks the ports for Whatsapp. Can you forward these ports once or check if you have UPnP enabled (unfortunately I don’t know exactly where on your modem). Greetings Daniele
jcbang UPNp is under Media. But i cannot access Media because Media sharing is disabled. I need to enable DLNA which is in the Media tab.
Daniele_Sunrise jcbang Have you already tried to restart your modem and then your phone too? UPnP should also be visible in security or port forwarding. Otherwise we have to refer you to our support 0800 707 707, because we have no access to the modem settings from here. Greetings Daniele
jcbang Turned UPnP on and restarted phone and modem. Still does not work. I will call support. Thank you for your help.
