Jhors When I follow the instructions for attaching my Canon printer to my new Connect Box it asks for the WLAN PIN number. Does that exist? Is there another way to add the printer to my network. It worked fine with the old Horizon Box
pato Can’t you enter the pre-shared key (password) for the SSID on the printer? Maybe that’s what it means by PIN, but I doubt it a little. Don’t use WPS if you can avoid it.
Jhors I’ve tried using my iPad and the router password as an intermediary but that hasn’t worked (it did with the Horizon box) so am now left with the WPS route but without a PIN number ……
pato Have a look here at where to find the temporary WPS PIN number: https://www.upc.ch/pdf/support/en/manuals/internet/connectbox/connect-box-manual.pdf on page 33
Jhors Thank you, that looks promising. I will try that when I return to Switzerland but that may not be for a couple of months.
