Hi Daniele, thanks so much for checking!
Speed is not the problem, Internet connection is very fast. Just did a check, 889/105 Mbit/sec max, so fully up to my expectations. UID is 2072812251555177.
The problem is the LAN connection between Gigabox and my Mikrotik router. MT log from the last hour below. 3-5 sec disconnects which disconnect then also video calls etc.
I cannot find any error in Gigabox log, but I guess issues on the four Ethernet ports are simply not logged.
08:53:52 interface,info ether2-wan link down
08:53:56 interface,info ether2-wan link up (speed 1G, full duplex)
08:56:51 interface,info ether2-wan link down
08:56:57 interface,info ether2-wan link up (speed 1G, full duplex)
09:00:14 interface,info ether2-wan link down
09:00:18 interface,info ether2-wan link up (speed 1G, full duplex)
09:04:47 interface,info ether2-wan link down
09:04:51 interface,info ether2-wan link up (speed 1G, full duplex)
09:12:37 interface,info ether2-wan link down
09:12:41 interface,info ether2-wan link up (speed 1G, full duplex)
09:22:54 interface,info ether2-wan link down
09:22:59 interface,info ether2-wan link up (speed 1G, full duplex)
Maybe a hardware problem? Power supply?
