Hi Daniele, without rush since internet is working, can you check if there is a problem with my connection?
The day I reported Thursday, I found out TV was not working and had to reboot TV box.
As I said, it is strange. When I do a factory restore (30 sec), light ring do not turn off.
Turning light ring completely off via the slide bar (I don't want) doesn't do anything.
What @mastanikhan suggested, there is not such "Adopt changes".
Giga Box currently on bridge mode, white light.
thank you so much
