UPCZHCabe I try to understand your request:
The modem glows green with you also in router mode?
But does it work?
Does everything work?
What exactly does not work when you set the modem in bridge mode?
If you use your modem in bridge mode, can you please connect your router, or that of a colleague, and set the router (your router, not the UPC Modem)to factory settings?
If I didn't understand your question, I would be glad if you could explain what doesn't work. Let's leave out the color thing.
Greetings
