Good morning,
Being the wifi power of the connect box very weak, I need to amplify it in my apartment and I just would like to know if you can indicate a compatibile mesh system in the market. Another solution might be to replace the connect box with a router in the market but I don’t know if later I will have problem with the signal of UPC.
I am asking that because also your amplifier/repeter are not a good option in terms of power of the signal.
Thank you in advance for your help.
