Hi, I have trouble with the Connect Giga modem, which seems to be a bit buggy.
I previously had to separate the 2.4 Ghz and 5 Ghz network, so I could at least reach normal speed in the 5 Ghz network.
Unfortunately, the 2.4 Ghz network ist still very slow and I use it to stream music and for smart devices. Max 35 Mbps in the speed test.
What are my options? Could you provide a fix or send me another modem type please?
Thank you
