PeterPark I checked all the cables and it won’t turn on. Neither the remote control nor the front switch nor the rear switch work.
Daniele_Sunrise PeterPark Have you checked the power supply, as well as the plug? Does the socket where you connected the UPC TV box have power? Greetings Daniele
PeterPark Daniele_Sunrise Thank you Daniele. Yes of course. The GIGA CONNECT BOX uses the same socket and it works well.
Daniele_Sunrise PeterPark We have just initiated a replacement of the UPC TV Box. YOU will get a replacement in the next few days. Greetings Daniele
