I’m using the Connect Box, and my broadband connection has now been down for more than 4 hours.
- In the overview panel, the “Your Connect Box status” shows red arrows for Internet, with “DS scanning”.
- I ran the Network diagnostic tool, which indicates “Your broadband connection is down. Please check your coaxial cable.”
- I checked the coaxial cable and re-plugged it on both ends, it still doesn’t work.
- I reset the box to factory defaults, it still doesn’t work.
- On the other side, my Service Status page at https://www.upc.ch/en/myupc/service/service-status shows everything available.
There were also the following “network logs” in the box, I indeed remember the connection dropping sometime between 15:10 and 15:20 today, which correlates with the various errors at 15:17.
01-01-1970 00:26:14 notice GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.0.73];CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
01-01-1970 00:01:23 notice Cable Modem Reboot - due to power reset;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:17:56 notice Illegal - Dropped FORWARD packet: SRC=192.168.0.136 MAC=zz:zz:zz:zz:zz:zz;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:17:51 notice TR069 stop ;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:17:49 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:17:26 notice Illegal - Dropped FORWARD packet: SRC=192.168.0.136 MAC=zz:zz:zz:zz:zz:zz;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:17:19 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:16:58 warning Lost MDD Timeout;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 15:16:52 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
08-06-2021 14:35:19 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=yy:yy:yy:yy:yy:yy;CM-QOS=1.1;CM-VER=3.0;
What else can I do? Can you send a technician to check that the broadband is indeed working at the coaxial plug on my wall, as reported by the Service Status?
