Daniele_Sunrise Uninstalled it,restarted computer…Same result, without it…Also did a test, just with the Cellphone, as only device connected to the modem…just to make sure…nothing…
Just a thought on my end: someone from your tech hotline, told me last Friday (when I first called), that there was a firmware update, for the modem, last Thursday and that was the day, when my problems started…Could it be, that there is something faulty with new update and maybe you could go back to the older one and we see if it might cause the problem ?
