itsthefoxtrot I’ve recently bought an internet and basic TV package, and setup the internet fine with the white ConnectBox router. But how do I setup the television now?
itsthefoxtrot Hi thanks for your reply. Trying those steps still doesn’t come up with any results 🙁 I’ve got my router connected to the wall with three holes, and the aerial is plugged directly into the TV from another cable which comes straight out of the wall.
[deleted] If you run an automatic digital channel search you should be able to receive all of the channels. Press the MENU button, then choose the automatic digital search cable with the parameters of your living address. https://www.upc.ch/en/support/setup-id/ I’ ve found a guide how to do a channel search for different TV models on the homepage of another provider. I hope it’s helpful to you (in German): https://www.yetnet.ch/downloads (source)
