You should post this in the French section, not the English one.
* EDIT * Someone moved the post to the French section.
But to answer your question… no.
If you roam to Germany for example, calls within Germany, from Germany back to Switzerland and receiving calls *are* included. Any other calls, such as Germany to France, or if you’re not roaming and call from Switzerland to Germany, aren’t included.
