Oh Wow!
This thing looks great and exactly what I need. It somehow is a little different to what I expected.
I expected a little device that can output all onto network, then at the other end it could pick up the signal from the network and put it back to the coax so I can use the upc cablecom set top box.
So I am guessing I don’t even needs UPC Cablecom set top box and this will just pump all the channels onto the network and I just need software or correct hardware to pick them up?
Couple of other questions:
1. I have read some of the documentation, and there are so many acronyms that I dont understand all of it, I was wondering, so from the upc cablecom coming into the house, which connector would I connect that too, I can see VL, VH, HL and HH?
2. Because this device has the ethernet connections, will this also provide the ethernet supplied from the UPC Cablecom which means I dont need to use the UPC cable com router either?
Thanks loads already, this is getting me much closer to a nice set up.
Richard
