I would need support with this:
Why can I only access my Kittyo when I’m on my home WiFi?If your network is behind a firewall, your router may be blocking outside connections. If port forwarding is something you are comfortable doing on your own, simply forward TCP ports 40,000 & 40,001 and point them to your Kittyo.
When I go to the port forwarding section of my admin panel I cannot create any additional port forwarding. How come? What’s the procedure?
Thanks.
