You should call the technical support of UPC 0800 66 88 66, they can have a look at the provisioning.
But more plausible is a problem with the signal. That can only be resolved by a technician of UPC. He has the required measure instruments to check the signal at your socket.
The cable are connected properly, as seen in the setup sheet?
