My voicemail box is full and when I key in my PIN to empty it I get an long error message -
500 Servlet Exception
com.openwave.paf.config.ConfigException: Key: confServHost not found in
config.db
at com.openwave.paf.config.intermail.IntermailConfig.do(Unknown Source)
at com.openwave.paf.config.intermail.IntermailConfig.try(Unknown Source)
at com.openwave.paf.config.intermail.IntermailConfig.get(Unknown Source)
at com.openwave.paf.config.Config.get(Unknown Source)
at com.openwave.paf.config.intermail.IntermailConfig.init(Unknown Source)
at com.openwave.paf.config.intermail.IntermailConfig.<init>(Unknown Source)
at com.openwave.paf.config.intermail.IntermailConfigProvider.getConfig(Unknown Source)
at com.openwave.paf.config.Config.getInstance(Unknown Source)
at com.openwave.mail.intermail.InitIntermailStore.init(Unknown Source)
at javax.servlet.GenericServlet.init(GenericServlet.java:69)
at com.caucho.server.dispatch.ServletConfigImpl.createServlet(ServletConfigImpl.java:599)
at com.caucho.server.dispatch.ServletManager.init(ServletManager.java:152)
at com.caucho.server.webapp.Application.start(Application.java:1697)
at com.caucho.server.deploy.Entry.startImpl(Entry.java:498)
at com.caucho.server.deploy.Entry.redeployIfModifiedImpl(Entry.java:452)
at com.caucho.server.deploy.Entry.startAutomatic(Entry.java:385)
at com.caucho.server.deploy.DeployContainer.start(DeployContainer.java:154)
at com.caucho.server.webapp.ApplicationContainer.start(ApplicationContainer.java:623)
at com.caucho.server.host.Host.start(Host.java:492)
at com.caucho.server.host.HostContainer.start(HostContainer.java:507)
at com.caucho.server.resin.ServletServer.start(ServletServer.java:894)
at com.caucho.server.resin.ResinServer.start(ResinServer.java:466)
at com.caucho.server.resin.Resin.init(Resin.java:297)
at com.caucho.server.resin.Resin.main(Resin.java:553)
How can I delete all the messages ???
