Hello Andrea_001
You can pair it with this Instruction:
If you pair your Horizon remote control with your TV set, you will no longer require a eparate remote for basic functions such as adjusting the volume of your TV set, switching it on and off, and selecting the signal source. A detailed description can also be found in the enclosed Quick Guide.
Please perform the following steps:
1. Look up your TV brand code:
2. Akai 0391, 0238, 0401, 1567, 0067, 0463, 0775, 0221, 0065, 0039, 0102, 0248, 0744, 0193, 0546, 0745, 0632, 0586, 0611, 0510, 0247, 0661, 0246, 0294, 0478, 0208, 0407, 0636, 1067, 1938, 0503, 0678, 0842
3. Switch the Horizon box off and switch your television on.
4. First press the “VOL – (minus)” button and then hold it and the “TV Source” button down for 5 seconds until the “TV ON/OFF” button flashes three times.
5. Enter the TV brand code via the keypad within 10 seconds.
6. Point the Horizon remote control at your TV set and hold the “TV ON/OFF” button down for up to a minute until the TV switches off. If your TV does not switch off, repeat steps 2 to 7. Immediately after your TV has switched itself off, first press the “VOL – (minus)” button and hold it and the “TV Source” button down again until the “TV ON/OFF” button flashes three times. This procedure stores the code in your remote control.
WARNING: If you wait too long after the TV has switched itself off, an incorrect code may be memorised. If this is the case, please repeat the procedure.
If it does not work, resett the pairing with this instruction and repeat steps with another code:
If you have mistakenly programmed an incorrect TV code on your Horizon remote control, then please proceed as follows to reset the remote control:
https://support-en.upc.ch/app/answers/detail/a_id/5887/kw/pairing
Greetings
Helpie
