Hi there,
I’ve recently moved into a new flat and ordered a UPC Connect Box. When I went to install it, I could not remove the plastic cover from what I assume to be the coax port. There is a message on the front that reads:
“Unerlaubtes entfernen dieser vignette hat verzeigung und schadenersatzforderung zur folge. Soll der anschluss wider in betrieb genommen werdern, melden sie sich bitte unter telefon 0800 668 866” I’ve attached a photo of the text.
I unfortunately do not speak German, so Google translate says it means there was some sort of unauthorized access and I need to call them to reinstate the connection. However, when I call, there’s not an option for an English rep, so I’m not really sure what to do. Any advice on what’s going on here would be greatly appreciated!
Cheers
