Hallo mog
Hier findest du ein Beispiel der Lizenz. Es ist nicht 1:1 das gleiche Modem, aber es sollte passen:
https://usermanual.wiki/Compal-Broand-Networks/CG6640A/info
Software License, Warranty, Safety, and Regulatory Information
CG6640A WiFi Cable Modem Gateway
SAFETY AND REGULATORY INFORMATION
IMPORTANT SAFETY INSTRUCTIONS — when using your equipment, basic safety precautions
should always be followed to reduce the risk of fire, electric shock, and injury to people, including
the following:
Read all of the instructions listed here and/or in the user manual before you operate this device.
Give particular attention to all safety precautions. Retain the instructions for future reference.
This device must be installed and used in strict accordance with manufacturer’s instructions,
as described in the user documentation that is included with the device.
Comply with all warning and caution statements in the instructions. Observe all warning and
caution symbols that are affixed to this device.
To prevent fire or shock hazard, do not expose this device to rain or moisture. The device must
not be exposed to dripping or splashing. Do not place objects filled with liquids, such as vases,
on the device.
This device was qualified under test conditions that included the use of the supplied cables
between systems components. To ensure regulatory and safety compliance, use only the
provided power
and interface cables and install them properly.
Different types of cord sets may be used for connections to the main supply circuit. Use only a
main line cord that complies with all applicable device safety requirements by the country of use.
Installation of this device must be in accordance with national wiring codes and conform to
local regulations.
Operate this device only from the type of power source indicated on the device’s marking label.
If you are not sure of the type of power supplied to your home, consult your dealer or local
power company.
Do not overload outlets or extension cords, as this can result in a risk of fire or electric shock.
Overloaded AC outlets, extension cords, frayed power cords, damaged or cracked wire
insulation, and broken plugs are dangerous. They may result in a shock or fire hazard.
Route power supply cords so that they are not likely to be walked on or pinched by items
placed upon or against them. Pay particular attention to cords where they are attached to plugs
and convenience receptacles, and examine the point where they exit from the device.
Place this device in a location that is close enough to an electrical outlet to accommodate the
length of the power cord.
Place device to allow for easy access when disconnecting the power cord of the device from the
AC wall outlet.
Do not connect the plug into an extension cord, receptacle, or other outlet unless the plug can
be fully inserted with no part of the blades exposed.
Place this device on a stable surface.
Avoid damaging the cable modem with static by touching the coaxial cable when it is attached
to the earth-grounded coaxial cable-TV wall outlet.
Always first touch the coaxial cable connector on the cable modem when disconnecting
Ethernet cable from the cable modem or user’s PC.
It is recommended that the customer install an AC surge protector in the AC outlet to which
this device is connected. This is to avoid damaging the device by local lightning strikes and
other electrical surges.
Postpone installation until there is no risk of thunderstorm or lightning activity in the area.
Do not use this product near water — for example, near a bathtub, washbowl, kitchen sink
or laundry tub, in a wet basement, or near a swimming pool.
Do not cover the device or block the airflow to the device with any other objects. Keep the
device away from excessive heat and humidity and keep the device free from vibration and dust.
Wipe the device with a clean, dry cloth. Never use cleaning fluid or similar chemicals. Do not
spray cleaners directly on the device or use forced air to remove dust.
Upon completion of any service or repairs to this device, ask the service technician to
perform safety checks to determine that the device is in safe operating condition.
Do not open the device. Do not perform any servicing other than that contained in the
installation and troubleshooting instructions. Refer all servicing to qualified service personnel.
This device should not be used in an environment that exceeds 40° C.
SAVE THESE INSTRUCTIONS
Note to CATV System Installer —This reminder is provided to call the CATV system installer’s
attention to EN60728-11:2005 standard, which provides guidelines for proper grounding and, in
particular, specifies that the Coaxial cable shield shall be connected to the grounding system of the
building, as close to the point of cable entry as practical.
CARING FOR THE ENVIRONMENT BY RECYCLING
When you see this symbol on a COMPAL BROADBAND NETWORKS, INC. product, do
not dispose of the product with residential or commercial waste.
Recycling your COMPAL BROADBAND NETWORKS, INC. Equipment
Please do not dispose of this product with your residential or commercial waste. Some
countries or regions, such as the European Union, have set up systems to collect and
recycle electrical and electronic waste items. Contact your local authorities for information
about practices established for your region. If collection systems are not available, call
COMPAL BROADBAND NETWORKS, INC. Customer Service for assistance.
International Declaration of Conformity
We,
13F, No1,Taiyuan St, Zhubei City,
Hsinchu County 30265,Taiwan(R.O.C)
886-3-560-0066
Declare under our sole responsibility that the
To which the declaration relates is in conformity with one or more of the following standards:
FCC STATEMENTS
FCC Interference Statement
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant
to part 15 of the FCC Rules.
These limits are designed to provide reasonable protection against harmful interference in a residential
environment. This equipment generates, uses, and can radiate radio frequency energy and, if not installed
and used in accordance with the instructions, may cause harmful interference to radio communications.
However, there is no guarantee that interference will not occur in a particular installation.
If this equipment does cause harmful interference to radio or television reception, which can be
determined by turning the device off and on, the user is encouraged to try to correct the interference
by one or more of the following measures:
‡5HRULHQWRUUHORFDWHWKHUHFHLYLQJDQWHQQD
‡,QFUHDVHWKHVHSDUDWLRQEHWZHHQWKHGHYLFHDQGUHFHLYHU
‡&RQQHFWWKHHTXLSPHQWLQWRDQRXWOHWRQDFLUFXLWGLIIHUHQWIURPWKDWWRZKLFKWKHUHFHLYHULVFRQQHFWHG
‡&RQVXOWWKHGHDOHURUDQH[SHULHQFHGUDGLR79WHFKQLFLDQIRUKHOS
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and (2) This device must accept any interference received,
including interference that may cause undesired operation.
FCC CAUTION: Any changes or modifications not expressly approved by Motorola for compliance
could void the user’s authority to operate the equipment.
FCC RADIATION EXPOSURE STATEMENT
This equipment complies with FCC radiation exposure limits set forth for an uncontrolled environment.
To comply with the FCC RF exposure compliance requirements, the separation distance
between the antenna and any person’s body (including hands, wrists, feet and ankles) must be at least
20 cm (8 inches). This transmitter must not be co-located or operating in conjunction with any other antenna
or transmitter except those already approved in this filing.
The availability of some specific channels and/or operational frequency bands are country dependent
and are firmware programmed at the factory to match the intended destinations. The firmware setting
is not accessible by the end user.
SOFTWARE LICENSE
CG6640A Cable Modem Gateway
Compal Broadband Networks, Inc.
13F, No1,Taiyuan St, Zhubei City, Hsinchu County 30265,Taiwan(R.O.C)
IMPORTANT: PLEASE READ THIS SOFTWARE LICENSE (“LICENSE”) CAREFULLY BEFORE YOU
INSTALL, DOWNLOAD, OR USE ANY APPLICATION SOFTWARE, USB DRIVER SOFTWARE, FIRMWARE,
AND RELATED DOCUMENTATION (“SOFTWARE”) PROVIDED WITH COMPAL BROADBAND NETWORKS,
INC.’S CABLE DATA PRODUCT (THE “CABLE DATA PRODUCT”). BY USING THE CABLE DATA PRODUCT
AND/OR INSTALLING, DOWNLOADING, OR USING ANY OF THE SOFTWARE, YOU INDICATE YOUR
ACCEPTANCE OF EACH OF THE TERMS OF THIS LICENSE. UPON ACCEPTANCE, THIS LICENSE WILL
BE A LEGALLY BINDING AGREEMENT BETWEEN YOU AND COMPAL BROADBAND NETWORKS, INC..
THE TERMS OF THIS LICENSE APPLY TO YOU AND TO ANY SUBSEQUENT USER OF THIS SOFTWARE.
IF YOU DO NOT AGREE TO ALL OF THE TERMS OF THIS LICENSE (I) DO NOT INSTALL OR USE THE
SOFTWARE AND (II) RETURN THE CABLE DATA PRODUCT AND THE SOFTWARE (COLLECTIVELY,
“PRODUCT”), INCLUDING ALL COMPONENTS, DOCUMENTATION, AND ANY OTHER MATERIALS
PROVIDED WITH THE PRODUCT, TO YOUR POINT OF PURCHASE OR SERVICE PROVIDER, AS THE
CASE MAY BE, FOR A FULL REFUND. BY INSTALLING OR USING THE SOFTWARE, YOU AGREE TO BE
BOUND BY THE PROVISIONS OF THIS LICENSE AGREEMENT.
The Software includes associated media, any printed materials, and any “on-line” or electronic
documentation, as well as any updates, revisions, bug fixes, or drivers obtained by you from COMPAL
BROADBAND NETWORKS, INC. or your service provider. Software provided by third parties may be
subject to separate end-user license agreements from the manufacturers of such Software.
The Software is never sold. COMPAL BROADBAND NETWORKS, INC. licenses the Software to the
original customer and to any subsequent licensee for personal use only on the terms of this License.
COMPAL BROADBAND NETWORKS, INC. and its third party licensors retain the ownership of the
Software.
You may:
USE the Software only in connection with the operation of the Product.
TRANSFER the Software (including all component parts and printed materials) permanently to another
person, but only if the person agrees to accept all of the terms of this License. If you transfer the
Software, you must at the same time transfer the Product and all copies of the Software (if applicable)
to the same person or destroy any copies not transferred.
TERMINATE this License by destroying the original and all copies of the Software (if applicable) in
whatever form.
You may not:
(1) Loan, distribute, rent, lease, give, sublicense, or otherwise transfer the Software, in whole or in part,
to any other person, except as permitted under the TRANSFER paragraph above. (2) Copy or
translate the User Guide included with the Software, other than for personal use. (3) Copy, alter,
translate, decompile, disassemble, or reverse engineer the Software, including, but not limited to,
modifying the Software to make it operate on non-compatible hardware. (4) Remove, alter, or cause
not to be displayed any copyright notices or startup message contained in the Software programs or
documentation.
The Product is not designed or intended for use in on-line control of aircraft, air traffic, aircraft
navigation, or aircraft communications; or in design, construction, operation, or maintenance of any
nuclear facility. COMPAL BROADBAND NETWORKS, INC. AND ITS THIRD PARTY LICENSORS
DISCLAIM ANY EXPRESS OR IMPLIED WARRANTY OF FITNESS FOR SUCH USES. YOU
REPRESENT AND WARRANT THAT YOU SHALL NOT USE THE PRODUCT FOR SUCH
PURPOSES.
COMPAL BROADBAND NETWORKS, INC. is not responsible for any third party software provided as
a bundled application, or otherwise, with the Software.
WARRANTY INFORMATION
Cable Modem Gateway
What is my limited warranty? A limited warranty for this Product (including Software) is provided by COMPAL
BROADBAND NETWORKS, INC. to your distributor, cable operator, or Internet service provider, as applicable.
Please contact your cable operator or Internet service provider (“Service Provider”) for details. COMPAL
BROADBAND NETWORKS, INC. does not warrant that any Software will perform error-free or without bugs.
COMPAL BROADBAND NETWORKS, INC.’s warranty shall not apply: (i) to any Product subjected to accident,
misuse, neglect, alteration, Acts of God, improper handling, improper transport, improper storage, improper use
or application, improper installation, improper testing, or unauthorized repair; or (ii) to cosmetic problems or
defects which result from normal wear and tear under ordinary use, and do not affect the performance or use of
the Product. COMPAL BROADBAND NETWORKS, INC.’s warranty applies only to a Product that is
manufactured by COMPAL BROADBAND NETWORKS, INC. and identified by COMPAL BROADBAND
NETWORKS, INC.-owned trademarks, trade names, or product identification logos affixed to the Product.
COMPAL BROADBAND NETWORKS, INC. DOES NOT WARRANT THIS PRODUCT DIRECTLY TO YOU,
THE END USER. EXCEPT AS DESCRIBED IN THIS SECTION “WARRANTY INFORMATION.” THERE ARE
NO WARRANTIES OR REPRESENTATIONS OF ANY KIND RELATING TO THE PRODUCT, EXPRESS,
IMPLIED, OR STATUTORY, INCLUDING BUT NOT LIMITED TO IMPLIED WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR WARRANTY AGAINST
INFRINGEMENT. COMPAL BROADBAND NETWORKS, INC. IS NOT RESPONSIBLE FOR, AND PROVIDES
“AS IS,” ANY SOFTWARE SUPPLIED BY 3RD PARTIES.
What additional provisions should I be aware of? Because it is impossible for COMPAL BROADBAND
NETWORKS, INC. to know the purposes for which you acquired this Product or the uses to which you will put
this Product, you assume full responsibility for the selection of the Product for its installation and use. While
every reasonable effort has been made to insure that you will receive a Product that you can use and enjoy,
COMPAL BROADBAND NETWORKS, INC. does not warrant that the functions of the Product will meet your
requirements or that the operation of the Product will be uninterrupted or error-free. COMPAL BROADBAND
NETWORKS, INC. IS NOT RESPONSIBLE FOR PROBLEMS OR DAMAGE CAUSED BY THE INTERACTION
OF THE PRODUCT WITH ANY OTHER SOFTWARE OR HARDWARE.
How long does this Limited Warranty last? Contact your Service Provider for details.
What you must do to obtain warranty service. For Product customer service, technical support, warranty claims,
questions about your Internet service or connection, contact your Service Provider. ALL WARRANTIES ARE
VOID IF THE PRODUCT IS OPENED, ALTERED, AND/OR DAMAGED.
THESE ARE YOUR SOLE AND EXCLUSIVE REMEDIES for any and all claims that you may have arising out
of or in connection with this Product, whether made or suffered by you or another person and whether based in
contract or tort.
IN NO EVENT SHALL COMPAL BROADBAND NETWORKS, INC. BE LIABLE TO YOU OR ANY OTHER
PARTY FOR ANY DIRECT, INDIRECT, GENERAL, SPECIAL, INCIDENTAL, CONSEQUENTIAL,
EXEMPLARY, OR OTHER DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PRODUCT
(INCLUDING, WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS
INTERRUPTION, LOSS OF INFORMATION, OR ANY OTHER PECUNIARY LOSS), OR FROM ANY BREACH
OF WARRANTY, EVEN IF COMPAL BROADBAND NETWORKS, INC. HAS BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES. IN NO CASE SHALL COMPAL BROADBAND NETWORKS, INC.’S
LIABILITY EXCEED THE AMOUNT YOU PAID FOR THE PRODUCT.
© COMPAL BROADBAND NETWORKS, INC.
2012. All rights reserved.
