Dears,
I discovered some random port forwarding settings on my router.
I would like to know why, and if I need to get any action.
Please also note the “error_translate”. These, might be, that I just set up a WD mycloud.
But it sounds a bit scary if the WD NAS can change my router settings.
Also the other UDP ports, which I have manually disabled, are on IPs on the DHCP. I have most of my devices outside of the DHCP range (I fixed by hand IP/HW association).
Any of you has an idea?
Thanks a lot in advance.
A+
F
