@Daniele_Sunrise unfortuntately not 🙁
For example; after authentication on port 5900, when i want to switch to channel 15 (just as example) i would need to send these commands:
040100000000e301
040000000000e301
040100000000e305
040000000000e305
The first part “040100000000” is key DOWN
The second line “040000000000” is key UP
The last 4 digits represent the list like below;
DIGIT_0: ‘e300’,
DIGIT_1: ‘e301’,
DIGIT_2: ‘e302’,
DIGIT_3: ‘e303’,
DIGIT_4: ‘e304’,
DIGIT_5: ‘e305’,
DIGIT_6: ‘e306’,
DIGIT_7: ‘e307’,
DIGIT_8: ‘e308’,
DIGIT_9: ‘e309’,
etc.
So i need the corresponding ‘last’ parts for the IR codes you mentioned. Can you help there?
