Daniele_Sunrise @zakai , Welcome to the Community! We have just switched your modem. Greetings Daniele
Daniele_Sunrise @EvilKnowsMe , Welcome to the Community! Please contact your provider in Austria. Greetings Daniele
Daniele_Sunrise @Ogret , Welcome to the Community! Your modem has already been switched to IPv4. Greetings Daniele
Ogret Hello togheter @Daniele_Sunrise could you please also change my device for IPv4. I will use the DMZ Mode as well. I called the support but nothing happend until now. Thanks.
Daniele_Sunrise @JakubBialek , Welcome to the Community! Your modem has been switched to IPv4. Greetings Daniele
JakubBialek Dear Daniele @Daniele_Sunrise I would like to kindly request switching on the IPv4 functionality in order to enable port forwarding. Thank you. Best regards, Jakub
evanbuiova Hi Daniel, mine doesn’t have the port forwarding option too, can you fix that for me, thank you so much.
Ahmet_sunrise Hi @Tibi & @Theodoros Welcome in our community! @Theodoros Yours is already done. @Tibi Please send me a private message with your customer number. Cheers, Ahmet
Theodoros @Daniele_Sunrise Hi Daniele, I see a lot of requests regarding changing the setting to IPv4 on Connect Box. I would like as well to enable the port forwarding on my router. Would that be possible? Thank you in advance! Theodoros
Daniele_Sunrise @Sergiu , Please send me your customer number via private message so that I can switch your modem to IPv4. Greetings Daniele
Daniele_Sunrise @zetariah , please contact UPC Austra Customer Service for IPv4 activation. Greetings Daniele
